Connecting 2 Computers with different external IP address
neoxmel
Post by neoxmel » Tue Oct 16, 2018 2:31 pm
I've been trying to connect 2 computers with different external ip address.
1 computer is the one who runs the SoftEther VPN Server manager and the other one is the client.
I set-up the server and created a certificate. I copied the certificate to the other pc (which has a different external IP) and used the certificate on user authentication settings on client manager. The hostname that I used to setup a new vpn connection was the 'DDNS Hostname' which is vpn(seriesofnumbers).softether.net > Clicked OK > Connect.
When I connect, an error appears that says
Error (Error Code 1):
"Connection to the server failed. Check network connection and make sure that address and port number of destination server are correct."
Now, I tried to connect it to a similar external ip address with the server and it did not encounter this kind of error.
Did I miss something up?
I'm new to setting this up and I'm honestly not sure what i'm doing.
Would appreciate some help.
Thanks.
sajer
Re: Connecting 2 Computers with different external IP address
Post by sajer » Tue Oct 16, 2018 2:45 pm
did you forward the port what is used for the vpn connection in the router?
GL
neoxmel
Post by neoxmel » Tue Oct 16, 2018 2:58 pm
Yes I did, I used port 5555 to port forward, also used that on the server in creating the hub, but I was not able to restart the modem/router since everyone here is using it, is it required to restart the router after port forwarding?
cmd wh0ami
Post by cmd wh0ami » Tue Oct 16, 2018 6:48 pm
i'm about 98% sure you can't use the same Sever/Client certificate for the user certificate. Your going to have to make a new cert for the user... The way you wrote your opening post, it sounds like that's what you did.
neoxmel
Post by neoxmel » Tue Oct 16, 2018 6:52 pm
When I created the server it asked me to create a user which I then created, there's an option there called 'Individual Certificate Authentication Settings' under Create New User and that's where I created the certificate for the user and used that certificate on the client computer.
neoxmel
Post by neoxmel » Wed Oct 17, 2018 2:23 pm
Update:
Should I be using my external IP as VPN Server Hostname or my internal IP address? I port forwarded the ports that SoftEther suggested (5555, 1194, 992, 443) and restarted the router but still no effect. What did I do wrong?
cmd wh0ami
Post by cmd wh0ami » Wed Oct 17, 2018 5:36 pm
If you left the dynamic DNS server enabled you can use the dns host name. Other than that, use the external (public) ip. If you enable SecureNAT it should punch a hole in whatever firewall is blocking you if that's your issue.
neoxmel
Post by neoxmel » Wed Oct 17, 2018 5:50 pm
Tried all of those things but still has this error:
neoxmel
Post by neoxmel » Fri Oct 19, 2018 1:13 pm
Hi guys,
Been testing things for days now, still nothing works. Any recommendations, solutions?
cmd wh0ami
Post by cmd wh0ami » Mon Oct 22, 2018 2:54 pm
Want is the server software running on? Windows, or Linux?
If you want to make things easy you should start out the fresh server install by doing it like this tutorial. And using Passwd Auth... There is a lot of different ways to do it but this way seems to always work for me no matter what's in between the server and client.
https://forum.icoexist.io/t/how-to-conf ... manager/32
Do what you want with the L2TP/IPsec OpenVPN and MS-SSTP settings, I disable everything but OpenVPN.
neoxmel
Post by neoxmel » Mon Oct 22, 2018 3:06 pm
Okay i'll try to follow the link that you gave me.
Sorry i'm not familiar with these terms, but, what I know is I also disabled everything (firewalls, etc..). The only tool that I use is SoftEther VPN. I'm not using OpenVPN
cmd wh0ami
Post by cmd wh0ami » Mon Oct 22, 2018 3:25 pm
They are different VPN protocols. Which will allow you to connect to the VPN with different VPN clients. Ie. there is no SoftEther client that works for iOS or Android without root. So you would have to use L2TP/IPsec or OpenVPN since there are clients for those protocols.
neoxmel
Post by neoxmel » Mon Oct 22, 2018 3:29 pm
So I tried the instructions on the link that was provided and I still got the same error.
NOTE:
I'm trying to connect a vpn from one place to another, that IS possible, right?
Also using both PC and SoftEther VPN Client on the client's side, i'm not using OpenVPN.
cmd wh0ami
Post by cmd wh0ami » Mon Oct 22, 2018 3:41 pm
Are you able to connect to the VPN server manager from outside your LAN? Is the server software on Linux or Windows?
Can you open a Command Prompt in Windows and ping your dns hostname from outside and inside the network?
ping -4 vpn(seriesofnumbers).softether.net
neoxmel
Post by neoxmel » Mon Oct 22, 2018 3:45 pm
No I'm unable to connect to the VPN server manager outside my lan. Server is on Windows 10.
I could ping my dns hostname inside my network but not outside my network.
I think i'm missing something, is there anything I did wrong?
cmd wh0ami
Post by cmd wh0ami » Mon Oct 22, 2018 4:00 pm
Yea, your firewall on the router to the WAN is blocking you.
You need to open up at least tcp port 443 on the router and forward it to the local ip of you vpn server. You should be able to do that while its being used. if it does go down it will only be for a second and no one would know the difference...
I just find it really had to believe that if you enabled SecureNAT it wont punch a hole in the firewall for you. You didn't disable NAT-T on the client did you?
neoxmel
Post by neoxmel » Mon Oct 22, 2018 4:05 pm
No I believe I did not touch any settings on the client, I just set it up normally, input my username/password and virtual hub. That's it.
I'll try and forward the port on the router see if it works.
Post by thisjun » Thu Nov 01, 2018 8:10 am
As first, let's isolate the problem
Do a client or a server manager can connect the VPN server from the same LAN?
If it fails, the cause of the problem may be the personal firewall.
What error did you see?
Was the ddns name resolved?
Can the client connect to another VPN server?
