How to increase number of tcp connections using OpenVPN client
cmd wh0ami
Post by cmd wh0ami » Sun Oct 21, 2018 9:28 pm
Does anyone know how to increase the number of tcp connections from 1 using openpvn built into softether? Also how to enable half duplex mode? I see in the server log when connecting with OpenVPN it says:
2018-10-21 21:09:08.246 Session "SID-WHOAMI-[OPENVPN_L2]-384": The parameter has been set.
Max number of TCP connections: 1, Use of encryption: Yes, Use of compression: No,
Use of Half duplex communication: No, Timeout: 20 seconds.
so this leads me to believe there's a way to increase the number of tcp connections and enable half duplex mode using the OVPN protocol.. Although there is nothing in the openvpn documentation. I'm thinking its a softether thing that might carry over to OPVN with the right custom options in the OVPN client.
Re: How to increase number of tcp connections using OpenVPN client
Post by thisjun » Thu Nov 01, 2018 7:47 am
OpenVPN protocol doesn't support multiple TCP connections.
