Block Network Scan
larry72450
Block Network Scan
Post by larry72450 » Mon Oct 29, 2018 7:46 pm
I have Windows SoftEther setup on Windows 10 Pro, latest version and am able to connect from home and do obtain a new ip. It then points me to a web page. This all works great.
I have my users setup with active directory to log in, and this works great.
All I want my users to do is get an ip, then with Set the Message, they are redirected to the webpage.
Currently they can scan the network, and see all my work computers. They do not need this access.
Maybe just the 10.0.30.1 dhcp server,gateway server.
I would like all ip's block. 10.0.0.0. 10.0.30.0 etc.
I am currently connection Direct TCP/IP
I think I could do this with a switch setting, but someone will have to walk me through this.
Conclusion: Users need to get ip, then redirected to webpage. No other access needed.
Any help would be appreciated.
Re: Block Network Scan
Post by thisjun » Thu Nov 15, 2018 7:41 am
Did you try "AccsessList" function?
https://www.softether.org/4-docs/1-manu ... ccess_List
