VPN client cant see host pc
JerryCZ
Post by JerryCZ » Fri Nov 16, 2018 8:47 am
Hi
I was looking for a forum, but nowhere I found anything to solve my problem.
in my home network I have a cisco router with a public ip and with dhcp servr. behind them are 2 PCs (one standard PC1, one as a data server PC2 with debian).
on PC2 I installed vpnserr, created a user, turned off dhcp and created a bridge between the hub and the physical ethernet.
if I connect to my ip from the outside of PC3, cisco me redirects to the VPN server, I connect and use cisco to assign IP to me.
and now to the problem. if I connect from the outside, then this PC3 sees PC1 (shared directories) as well as PC1 sees PC3 but PC3 connected from outside does not see shared directories on PC2 where the VPN server is running.
what can be wrong?
I tried different settings and try and nothing.
If another PC4 is connected to the VPN, the scenery is the same, it sees PC1, sees PC3 but does not see PC2.
Re: VPN client cant see host pc
Post by thisjun » Tue Dec 11, 2018 2:02 am
There is the limitation of localbrige with Linx.
https://www.softether.org/4-docs/1-manu ... r_Mac_OS_X
