[Solved]RADIUS passwords are cut off after 23 characters
strob
Post by strob » Fri Nov 16, 2018 11:42 am
Hey everyone,
is it possible, that the Softether VPN Client cuts passwords with RADIUS authentication after 24 (respectively 23) characters?
I have a Softether VPN Server (4.28.9669) on Ubuntu 18.04 running with a local freeradius server.
I modified my freeradius config to print out the password in plain text and found different behaviors of cutting the password.
username: test.user
password: 1234567890123456789012345678901234567890
set password in the GUI (version (windows version 4.27 9668 via wine):
Fri Nov 16 10:17:10 2018 : ERROR: (0) scriptauth: ERROR: Program returned code (1) and output 'Reply-Message = "user: test.user - pass: 123456789012345678901234",Auth-Type = Reject,Reply-Message = "Username or password incorrect."'
set password in the CLI (version 4.27.9668):
/opt/vpnclient/vpncmd localhost /CLIENT /CMD AccountPasswordSet test /PASSWORD:123456789012345678901234567890 /TYPE:radius
Fri Nov 16 11:00:13 2018 : ERROR: (78) scriptauth: ERROR: Program returned code (1) and output 'Reply-Message = "user: test.user - pass: 12345678901234567890123",Auth-Type = Reject,Reply-Message = "Username or password incorrect."'
send a radius request with radtest from the server:
radtest -x test.user '1234567890123456789012345678901234567890' 127.0.0.1 1812 <radiussecret>
Sent Access-Request Id 150 from 0.0.0.0:34465 to 127.0.0.1:1812 length 111
User-Name = "test.user"
User-Password = "1234567890123456789012345678901234567890"
NAS-IP-Address = 127.0.1.1
NAS-Port = 1812
Message-Authenticator = 0x00
Cleartext-Password = "1234567890123456789012345678901234567890"
Received Access-Reject Id 150 from 127.0.0.1:1812 to 0.0.0.0:0 length 113
Reply-Message = "user: test.user - pass: 1234567890123456789012345678901234"
(0) -: Expected Access-Accept got Access-Reject
Can someone else confirm this? Should i open an issue in github for this?
Regards strob
davidebeatrici
Re: RADIUS passwords are cut off after 23 characters
Post by davidebeatrici » Sun Nov 18, 2018 6:54 pm
Please open an issue on GitHub, so that we keep track of it.
Regards.
strob
Post by strob » Fri Nov 30, 2018 9:21 am
i figured it out and it was totally my fault.
i did cut the last 6 chars from the password to compare it with a MFA token and i had one error in my code, which made the difference between CLI and GUI..
Sorry!
fenice
Re: [Solved]RADIUS passwords are cut off after 23 characters
Post by fenice » Fri Nov 30, 2018 10:14 am
That's good to hear you've solved it and thanks for the feedback. :)
Regards
Bill
