chromebook client
chromebookfan22
chromebook client
Post by chromebookfan22 » Thu Nov 29, 2018 5:51 pm
I am writing to ask if a softether client is being developed for the chrome book? I
cmd wh0ami
Re: chromebook client
Post by cmd wh0ami » Thu Nov 29, 2018 11:06 pm
There's already a client that works with Chromebook... The Linux version....
ChromeOS is Linux... So if you put the Chromebook in Dev mode, download and install Crouton... And install a Command Line Only version of Ubuntu, you can run the Linux client.
I have a Chromebook and run Softether Client on it daily..
chromebookfan22
Post by chromebookfan22 » Thu Nov 29, 2018 11:44 pm
I appreciate your reply and trying to help. I am asking about an actual client for chrome book that I can download from the play store and install and run without dev mode or any other work around...
cmd wh0ami
Post by cmd wh0ami » Thu Nov 29, 2018 11:58 pm
Your post wont get much if any action here. You should post a feature request on SoftEther's GitHub, you'll have better luck getting a response...
But for having a username like Chromebookfan... I'm shocked you would even think of using a Chromebook without being in Dev mode? You literally can not do ANYTHING with it but visit websites...
chromebookfan22
Post by chromebookfan22 » Fri Nov 30, 2018 12:25 am
I will post a request on github.
There are 3 million apps on the play store. Hundred(s) of them are vpn clients. Pretty sure none of them need to be run in dev mode from the cli.
cmd wh0ami
Post by cmd wh0ami » Sat Dec 01, 2018 5:09 pm
If your talking apps, these is a 3rd party SoftEther Client for android. It requires root for android.. But might work on a Chromebook?
https://play.google.com/store/apps/deta ... &hl=en_US
