Hi all
I'm using a SoftEther VPN Server to create "Always On" VPN connections for Windows Notebooks using certificate authentication on the virtual hub in combination with the "startup connection" feature. We setup a VPN user per Notebook (rather than per user who may work with the notebook) to be able to revoke the certificate e.g. if a Notebook gets stolen. The users on the notebook have normal user rights (no administrative rights) and are therefore not able to (easily) extract the configuration/certificate on the notebook to use it on another (e.g. home) machine which has to be prevented of course. But our security officer came up with the requirement to tie the VPN user to the machine, e.g. using the UUID of the machine or, even better, store the certificates for the VPN user in the TPM module of the Notebook, to make it impossible to use the configuration/certificate on another machine. As I have not found any hint in the documentation for this requirement nor found a proper forum post with an explanation how to set this up, I'd like to ask if there is a feature I'm missing or a different approach to meet this requirement?
Any hint will be very appreciated.
Thanks in advance!
Regards, Marco
Tie VPN user to a specific hardware
Re: Tie VPN user to a specific hardware
Hi all
Just wanted to ask again if somebody had the same requirement and was able to find a solution to implement it with SoftEther? Maybe a virtual smart card or something like this?
Any feedback would be highly appreciated.
Thanks in advance.
Regards, Marco
Thanks in advance.
Regards, Marco
Hi all
In the meantime, I read in the documentation that a virtual smart card is not an option, as a connection which uses smart card cannot be set to reconnect automatically because of the PIN required to access the smart card (I was hoping that one can setup a virtual smart card with a third-party software without the need to enter a PIN to access the certificate).
Any other ideas? If not I guess I have to enter a Feature request…
Thanks in advance.
Regards, Marco
Thanks in advance.
Regards, Marco
Please enter a feature request, I believe that it could be useful for many enterprise environments.
Best regards,
Davide
Best regards,
Davide
