Error 9 on clustering vpn server
adew07
Post by adew07 » Fri Dec 14, 2018 9:02 am
Hi everyone, i have problem with cluster vpn server
1 Cluster Controller (Controller Funct Only)
2 Cluster Member
1 static hub created on cluster controller and 1 user on hub.
When i try to connect to cluster controller ip address, there's an error like :
2018-12-14 15:58:05.606 [HUB "labs"] Connection "CID-102": User authentication failed. The user name that has been provided was "maman".
2018-12-14 15:58:05.626 Connection "CID-102" terminated by the cause "User authentication failed." (code 9).
I hope someone can give solution
topology attached
Thanks
