no more login for old users
jens.steuwer
Post by jens.steuwer » Mon Dec 17, 2018 2:55 pm
Hi I'm using Softether for a demo server for my customers.
My company is using VPN from watchguard (main firewall).
So i needed to setup Port 446 for Softether to get a route through the watchguard firewall.
I can work now with 15 Persons, with double logins, and so on, but 3 Users cannot get a connection from their machines anymore.
The only different to the other is, that they doesn't used it for some days.
As a test i tried to use their accounts on my PC without problems.
error message while login is Code 1 An error occured / Connection failed. Check network conection....
With smartsniff i could see my other connections, but not only on port 446.
Is there a count of ports we can reset or setup to enable a connect from these missing clients?
