Multiple connections
zapaska101
Post by zapaska101 » Wed Jan 02, 2019 10:21 am
How to connect to multiple IP at the same time through the Academic Experimental Project? I created several virtual adapters, but for some reason I cannot connect to several at the same time. How to do it?
raafat
Re: Multiple connections
Post by raafat » Thu Jan 10, 2019 3:22 pm
Hello there! It's not clear at all what you are trying to achieve. May you elaborate more on the issue you are facing so that we help you back?
