Internet through SE
cmpts_cpeacock
Internet through SE
Post by cmpts_cpeacock » Fri Jan 18, 2019 9:35 am
I've created a local bridge on Ubuntu using these sites as a guide:
http://blog.lincoln.hk/blog/2013/03/19/ ... er-on-vps/
http://blog.lincoln.hk/blog/2013/05/17/ ... al-bridge/
When I connect from Android using VPN Client Pro over SSTP the VPN connects fine, but all Internet is routed through SE too.
I think it's the nat tables, but when they weren't there there was no Intenet at all.
iptables -t nat -A POSTROUTING -s 192.168.30.0/24 -j SNAT --to-source 192.168.0.1
apt-get install -y iptables-persistent
How can I allow VPN clients to connect, but not route Internet through SE and only use their local network for Internet?
Cheers
elmoghazy.omar
Re: Internet through SE
Post by elmoghazy.omar » Fri Jan 18, 2019 1:13 pm
Hi, what you are trying to achieve is called "split tunneling" there's already a good guide on how to implement it on the forum:
viewtopic.php?f=7&t=59975&p=77412&hilit ... ide#p77412
cheers
cmpts_cpeacock
Post by cmpts_cpeacock » Fri Jan 18, 2019 1:19 pm
Thanks. That's Windows focussed, whereas I'm using Ubuntu.
I'll see if I can find any posts specific to Ubuntu / Linux and split tunnelling.
Cheers
