Hi, I'm using SoftEther VPN server as a L2TP server, it works correctly. I have only one VPN user name and password for the client.
But I found that when I have two VPN client connected, they will give the correct IP address (192.168.2.x) assigned. But if I have a third VPN client connected, I see that it got the wrong IP address (169.x.x.x).
This means the third VPN client has the wrong(not expected IP assigned).
I have see this option:
You see that I have 999 value set, and I see my issue is gone, I mean all the vpn client got correct IP assigned.
Am I correct? I mean by default, only two client is allowed?
Thanks.
SoftEther VPN default has 2 sessions limit for the L2TP client?
