hello I am Anthony Gharib.
I have a problem with the software, I have been trying to use it to access the lan connection of a laptop remotely using my lan but it didn't work with me I even checked your website for a solution but I wasn't able to find any.
I asked a friend about it and he told that my internet connection should be 800 mb/s, Is that true?
I would really appreciate it if you can help.
Thanks in advance
Sharing Lan connection using SoftEther
Re: Sharing Lan connection using SoftEther
it depends, what is your goal?I asked a friend about it and he told that my internet connection should be 800 mb/s, Is that true?
Would like to make your PC a gateway to others to connect thought your PC then connecting to the Internet?
if yes you need high UPLOAD speed 30M ~ 50M ~ more, but if you need it for yourself /
