Hi all ! The problem is this - I install it on a clean Mac OS Big Sur, after that I start the installation of the server ./.install.sh everything is loaded and installed Then ./vpnserver start -----
The SoftEther VPN Server service has been started.
Warning: The current user context is non-root. It is recommended to run the VPN service by the root user. Although the VPN service may run under non-root users, some privilege-required functions (e.g. the local bridge function) need the root privilege.
Let's get started by accessing to the following URL from your PC:
https://185.00.00.46:5555/
or
https://185.00.00.46/
Note: IP address may vary. Specify your server's IP address.
A TLS certificate warning will appear because the server uses self signed certificate by default. That is natural. Continue with ignoring the TLS warning.
Потом Then ./vpncmd - 1
enter and twice
ma@185 vpnserver % ./vpncmd
vpncmd command - SoftEther VPN Command Line Management Utility
SoftEther VPN Command Line Management Utility (vpncmd command)
Version 4.42 Build 9798 (English)
Compiled 2023/06/30 11:06:58 by buildsan at crosswin with OpenSSL 3.0.9
Copyright (c) 2012-2023 SoftEther VPN Project. All Rights Reserved.
By using vpncmd program, the following can be achieved.
1. Management of VPN Server or VPN Bridge
2. Management of VPN Client
3. Use of VPN Tools (certificate creation and Network Traffic Speed Test Tool)
Select 1, 2 or 3: 1
Specify the host name or IP address of the computer that the destination VPN Server or VPN Bridge is operating on.
By specifying according to the format 'host name:port number', you can also specify the port number.
(When the port number is unspecified, 443 is used.)
If nothing is input and the Enter key is pressed, the connection will be made to the port number 8888 of localhost (this computer).
Hostname of IP Address of Destination:
If connecting to the server by Virtual Hub Admin Mode, please input the Virtual Hub name.
If connecting by server admin mode, please press Enter without inputting anything.
Specify Virtual Hub Name:
Error occurred. (Error code: 1)
Connection to the server failed. Check network connection and make sure that address and port number of destination server are correct.
I tried to enter the IP of the machine - the result is the same
how to understand what is not working? and how to fix it?
sorry for my english - it's google translate
Install mac os big sur Error occurred. (Error code: 1)
