VPN Relay Servers not working
vervec
Post by vervec » Sun Feb 04, 2024 1:17 pm
VPN Relay Servers (free, public list) not working in Windows 10 (x64). Although it works in Windows 7 32 bit. How to fix?
Original operating systems.
Re: VPN Relay Servers not working
Post by solo » Sun Feb 04, 2024 10:05 pm
Works for me.
vervec
Post by vervec » Mon Feb 05, 2024 2:47 pm
I forwarded ports 5555, 992 in the router - it doesn’t work. A strange story began just a week ago, suddenly.
vervec
Post by vervec » Sun Feb 11, 2024 6:57 pm
Problem is relevant
vervec
Post by vervec » Mon Mar 04, 2024 7:27 pm
The problem is relevant, developers explain what the problem could be? Does not work in any localization Windows and IP address (RU or others). In Windows 7 (32 bit) working.
