mobiles can not connect while pc can connect
mhamdy55
Post by mhamdy55 » Tue Mar 28, 2017 7:08 am
hi , I have a strange problem , im at home , can use my pc to connect to my server , via my home Wifi
all computers can connect , but suddenly recently , mobiles can not connect to the vpn server
if I off the wifi on mobile and use 4G , it can connect smoothly , but using the wifi can not , while the computer can use the wifi to connect easily , I don't know what is the problem
thanks
Re: mobiles can not connect while pc can connect
Post by thisjun » Thu Apr 06, 2017 7:48 am
If the VPN server is in your home LAN, please try to specify private IP address as destination.
