I have 2 active virtual hubs that are currently online. The first hub is for cascade connection from datacenter to server and the second virtual hub for VPN remote access. In softether VPN client, I can easily choose the virtual hub after putting the IP address. However, I can't seem to find how to select virtual hub for VPN remote access when using OpenVPN. Is OpenVPN client can select VPN remote access virtual hub as target instead of keep going to first hub?
Thank you
OpenVPN Virtual Hub Target
Re: OpenVPN Virtual Hub Target
Please add '@' + virtual hub name after username.
Ex. user@virtualhubname
