Cascade connection - "Encryption: Disabled"
gg_user
Post by gg_user » Sat May 13, 2017 7:32 pm
Hello!
Is this the correct state of the bridge? So it should be?
(CentOS 7.2)
VPN Server/BRIDGE>sessionget sid-link-2
SessionGet command - Get Session Information
Item |Value
User Name (Authentication) |Cascade
VLAN ID |-
Server Product Name |SoftEther VPN Bridge (64 bit)
Server Version |4.22
Server Build |Build 9634
Connection Started at |2017-05-13 (Sat) 14:17:38
First Session has been Established since |2017-05-13 (Sat) 14:17:38
Current Session has been Established since |2017-05-13 (Sat) 14:17:38
Half Duplex TCP Connection Mode |No (Full Duplex Mode)
VoIP / QoS Function |Enabled
Number of TCP Connections |0
Maximum Number of TCP Connections |0
Encryption |Disabled (No Encryption)
Use of Compression |No (No Compression)
UDP Acceleration is Supported |No
UDP Acceleration is Active |No
Session Name |SID-LINK-2
VPN Server/VPNL2>sessionget sid-admin-2
Item |Value
Client IP Address |10.0.2.16
Client Host Name |10.0.2.16
User Name (Authentication) |admin
User Name (Database) |admin
VLAN ID |-
Server Product Name |SoftEther VPN Server (64 bit)
Current Session has been Established since|2017-05-13 (Sat) 14:17:38
Number of TCP Connections |8
Maximum Number of TCP Connections |8
Encryption |Enabled (Algorithm: AES256-SHA)
Physical Underlay Protocol |Standard TCP/IP (IPv4)
Session Name |SID-ADMIN-2
gg_user
Re: Cascade connection - "Encryption: Disabled"
Post by gg_user » Thu May 18, 2017 9:53 am
Hey guys, can you explain to me whether this is a problem or not?
Thanks.
Post by thisjun » Wed May 31, 2017 4:57 am
If destination of cascade is localhost, encryption isn't used for.
gg_user
Post by gg_user » Wed May 31, 2017 9:01 am
If the connection is from the server side?
vpnsrv(10.0.2.15) <----> vpnbr(10.0.2.16)
[root@vpnsrv vpnserver]# ./vpncmd
Hostname of IP Address of Destination: 10.0.2.16:443
VPN Server/BRIDGE>sessionget sid-link-3
Encryption | Disabled (No Encryption)
Post by thisjun » Thu Jun 15, 2017 4:49 am
Are these hosts clone?
If host identity are same, SoftEther VPN recognize destination is localhost.
gg_user
Post by gg_user » Fri Jun 16, 2017 2:27 pm
Initially I tested in a virtualbox on Mac. VMs were clones.
After that I tested it in vmware. Virtual machines are located on two hosts:
hostesxi1 and hostesxi2.
Result as in the previous post:
VPN Server/BRIDGE>sessionget sid-link-...
On the vpnbridge I done the following settings:
hub BRIDGE
CascadeCreate ...
CascadePasswordSet ...
CascadeOnline ...
Post by thisjun » Thu Jun 29, 2017 7:58 am
Please try to change host name of guest on the VM.
gg_user
Post by gg_user » Sat Jul 01, 2017 7:51 am
I changed the names of all VM hosts. Installed VM on hosts KVM and ESXi.
Post by thisjun » Wed Jul 12, 2017 6:39 am
Could you share the result?
gg_user
Post by gg_user » Thu Jul 13, 2017 11:51 am
Here are the logs and the connection diagram
log_vpn.txt
log
(14.35 KiB) Downloaded 102 times
diagram
Post by thisjun » Fri Jul 28, 2017 5:03 am
"SessionGet" command is showing status of session between virtual cascade device and virtual hub.
This is meaningless.
Please check status by "CascadeStatusGet" command.
gg_user
Post by gg_user » Sun Jul 30, 2017 11:15 am
Thank you!
A few more questions:
1. Will the MakeCert4096 command be added to one of the following versions?
2. Can I add /SetPassphrase to the MakeCert?
