It is currently Fri Aug 18, 2017 12:30 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Mon May 22, 2017 5:34 pm
i have a setup of VPN Server on Windows and a VPN Bridge on Ubuntu. I use this scenario also for other bridge connections that work fine, now this bridge is installed on a provider that runs openstack platform on kvm i have not used before (Prom mode is enabled).
the problem i have is that the Softether Tunnel seems to be up, i see the local ip of the bridge and also see the virtual IP from my L3 switch. but it seems there is no arp resolution possible trough the tunnel.
this is the example output from the bridge:
root@sevpngw:~# ip neigh
10.xx.12.251 dev eth0 FAILED
10.xx.12.1 dev eth0 lladdr fa:xx:xx:6c:da:17 REACHABLE
We have already checked a lot and i don't know where can be the issue. Any idea?
Top
 Profile
PostPosted: Wed May 31, 2017 5:22 am
There is limitation of localbridge on Linux.
http://www.softether.org/4-docs/1-manua ... r_Mac_OS_X
Top
 Profile
PostPosted: Wed May 31, 2017 9:43 am
thx. none of this limitations apply to us as this is running on either CentOS or Ubuntu (same issues on both OS). We have fullly root access to the machines
Top
 Profile
PostPosted: Thu Jun 15, 2017 4:52 am
>Limitations within the Linux or UNIX operating system prevent communication with IP addresses assigned to the network adapter locally bridged from the VPN side (Virtual Hub side).
Top
 Profile
PostPosted: Thu Jun 15, 2017 8:52 am
thx. i know this limitation. But this is not the problem here.
The IP address of the L3-Switch is for example not pingable from the subnet where the Bridge runs.
The tunnel is up. Also a network expert had a look and don't found the issue that arp is incomplete.
Top
 Profile
PostPosted: Thu Jun 29, 2017 7:49 am
It seems promiscuous mode doesn't work.
Could you re-check it?
Is the IP address of virtual L3 switch valid?
Top
 Profile
Search for:
Jump to:
Return to www.softether.org
