Get my LAN DHCP server to issue an address
ws7m
Post by ws7m » Fri May 26, 2017 1:06 am
Hi all,
I have a raspberry Pi and I've installed SoftEther on it. I have it at a static IP on my LAN. It's IP is 10.2.10.16 and my DHCP server for the LAN is at 10.2.10.1.
My goal is to be able to connect into this VPN server and get an IP on my local can so I can look at many different devices.
This does not seem to work. When I connect I get the waiting for DHCP but it never gives an address to the connected VPN client. I end up with the private IP 169.xxx. I have toyed with enabling NAT but that seems to do something kind of different.
I have a radio device that emits UDP packets so it can be found and connected to. I suspect if I use the NAT in the VPN server that these will not route. My ideal solution is to connect in and have my current DHCP server give me an IP.
Alternatively if I could figure out how to setup a static IP, on my LAN I'd be fine with that too. I will be the only VPN user.
What are my options? Thanks in advance!
Re: Get my LAN DHCP server to issue an address
Post by thisjun » Thu Jun 08, 2017 7:09 am
Did you create the localbridge with wifi device of the Pi?
If so, I guess promiscuous mode may not work.
