It is currently Fri Aug 18, 2017 12:31 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
PostPosted: Fri May 26, 2017 4:52 am
Hi..
I have tested connecting 2 Location via Softher VPN and it is successful.
LOCATION A- Softether VPN Server ( Windows 10) - LAN Class A
LOCATION B- Softwther VPN Client with Bridging. ( Windows 10) Manually Configure CLASS A IP for VPN- LAN Class B
Connection Successful.
Requirement : LOCATION B all Users can use Resource of LOCATION A. ( need Class A IP on LOCATION B Manually / DHCP)
How to manage all PC of LOCATION B to use resource of Location A.
- need to install softether on each and every PC?
- Installing on 1 PC and manage via IP to communicate with LOCAL B Softether Bridge?
How to setup? anyone can help?
Thanks in Advance.
Sam
Top
 Profile
PostPosted: Thu Jun 08, 2017 7:20 am
Please try SoftEther VPN Bridge instead of SoftEther VPN Client or enable bridge/router mode on SoftEther VPN Client.
Router is required for 1 PC configuration.
There are some methods which depend on what you use as a router.
1. Using virtual L3 switch.
http://www.softether.org/4-docs/1-manua ... IP_Routing)
2. Making the client a router.
3. Using another hardware router.
Top
 Profile
Search for:
Jump to:
Return to www.softether.org
