Dynamic DNS: Select preferred ethernet adapter?
wolfix
Post by wolfix » Fri May 26, 2017 10:34 am
thx in advance and sorry for my english :(
We have 2 ethernet adapters on our Windows 2008 R2 server :
#1 - ETHadapter1 (eth 0 port) (wired > router > ISP1 (300/300Mbps) > public dynamic IP)
#2 - ETHadapter2 (eth 1 port) (wired > router > ISP2 (20/3Mbps)> public dynamic IP)
The problem: the Dynamic dns Interface gets "always" the public ip of ETHadapter2. Only get the public ip from ETHadapter1 when we turn off ETHadapter2.
The network device priority in the advanced panel of network devices seems to be ok (ETHadapter1 in top)
The are any setting in SoftEther VPN Server Manager config file to set this priority?
Windows server 2008 R2
SoftEther VPN Server 44.0 (4.22)
Thanks!
Re: Dynamic DNS: Select preferred ethernet adapter?
Post by thisjun » Thu Jun 08, 2017 7:29 am
Packet is sent to DDNS server with device that default gateway is assigned on that device.
