Driver installation problem
bananasplitz
Post by bananasplitz » Sun Jun 04, 2017 5:11 pm
Whenever I try to install the network driver, a Windows firewall (is that it?) icon appears in taskbar for a second, then driver installation fails.
It doesn't give any errors as if installed successfully, but VPN network driver appears with Windows error 31 in the device manager and I can't connect to anywhere (SoftEther Manager says the driver is disabled).
I tried reinstalling, deleteing registery, I've even checked Windows firewall permissions and tried disabling it, but nothing helped.
Re: Driver installation problem
Post by thisjun » Thu Jun 15, 2017 5:47 am
Installing driver may fail by following causes.
Virtual LAN driver isn't signed.
Windows is broken.
Some security soft blocks installing.
