ACCESS VPN ONLY FOR LAN
Asura
Post by Asura » Tue Jun 06, 2017 9:09 am
Hello, I´m using this software and work perfectly, but, I have one problem.
I want to connect to my own server creates with this software but I only want to get access for lan, no internet.
I want continue using my internet connection because is more fast and I dont want to overcharge the server internet line.
The lan which I want to connect has a router that give DCHP directions. If I configure an static ip on client without gateway it works like I want, but I needed the network interface use a dinamic ip assigned by the router.
is there some configuration to do that?
Thank you.
Re: ACCESS VPN ONLY FOR LAN
Post by thisjun » Thu Jun 15, 2017 6:06 am
Try to increase interface metric of virtual NIC.
