Can I re-use the same dynamic DNS host name after a server crash ?
If so, how ?
Thanks in advance
Use of same DYNAMIC DNS HOST NAME after server crash
Re: Use of same DYNAMIC DNS HOST NAME after server crash
If you have backup of configuration file, you can use same DDNS name.
How to create backup? Can I use VPN Server Manager for Windows?
How to restore it then?
Thanks
Thanks
Backup file is created automatically in VPN server exe folder.
You can save backup to file from 'Edit Config'.
At first, please get current configuration.
After that, please overwrite DDNS key from backup file.
Then, please restore it by 'ConfigSet' command of vpncmd.
http://www.softether.org/4-docs/1-manua ... VPN_Server
If you want to use GUI, please restore it from 'Import File and Apply' of 'Edit Config'.
