MyProgram=Server on non-private IPv4 - is it possible?
ares
Post by ares » Sat Jun 24, 2017 6:16 pm
MyProgram = Server on port 7654 (and this can not be changed)
MyProgram = on non-private (not white, not dedicated) IPv4
MyClient = on private dedicated IPv4
MyClient controls MyProgramServer via port 7654 (and this can not be changed)
Question:
SoftEther VPN - can solve the problem of connecting MyClient from the Internet to MyProgramServer? If this is possible, how can this be done?
Important Condition:
SoftEther VPN on the side of MyProgramServer must be configured by the user with minimal computer knowledge and preferably completely automatically.
I would be grateful for any help.
Perhaps a monetary reward.
Re: MyProgram=Server on non-private IPv4 - is it possible?
Post by thisjun » Thu Jul 06, 2017 8:02 am
If you write the VPN installing manual, it may be possible.
ares
Post by ares » Sat Jul 15, 2017 12:11 pm
What do you mean about "manual"?
If is this manual for user... then
The level of my users is very low - they will not be able to customize the settings themselves. My users need a fully automatic installation.
Or is it install script? ...
Post by thisjun » Fri Jul 28, 2017 5:16 am
Please try "Easy Installer Creator" of SoftEther.
You can find it in start menu of Windows.
