SoftEther Vpn sevpmservice used too many RAM memory
ugator
Post by ugator » Tue Jun 27, 2017 11:49 am
Hi
on my pc SEVPNSERVICE used too many memory.
It started from 27 MB on first load, and then, after some hours service used 19 Gb of memory
I have only 10 clients.
Not use ddns and local bridge, enable only OpenVPN and SEVPN ports like 5555, and enable SE dhcp virtual.
I try to disable some configs, but no result.
Please help me! Someone give me worked normally configs.
Re: SoftEther Vpn sevpmservice used too many RAM memory
Post by thisjun » Thu Jul 06, 2017 8:04 am
What OS do you use?
jd14
Post by jd14 » Sun May 13, 2018 5:48 am
Do you still need help?
