isolated vpn accessing only to the same host server
openaspace
Post by openaspace » Tue Aug 15, 2017 1:36 pm
Hello
I have setup a rapsberry softether vpn server.
I have created a virtualhub with securenat-dhcp activated and I want to allow the clients to access only the same host vpn server that run a webserver on the physical lan.
How to do that?
Thanks you very much.
openaspace
Re: isolated vpn accessing only to the same host server
Post by openaspace » Wed Aug 23, 2017 10:50 am
No one know how to this configuration?
Thanks for the help
Post by thisjun » Thu Sep 14, 2017 6:49 am
Please try create tap mode localbridge.
Please disable virtual NAT and default gateway setting in DHCP server.
