Not assigned ip address
AlexeyMish
Post by AlexeyMish » Wed Aug 16, 2017 11:28 am
Installed and configured on amazon (and google) server.
The connection is established from the computer, but does not connect to the android device.
After the connection is established, no ip address is assigned to the computer.
I tried both locale bridge, and the SecureNAT.
ifconfig
eth0: flags=4419 mtu 1500
inet 172.31.43.Х netmask 255.255.240.0 broadcast 172.31.47.255
inet6 fe80::4f5:9fff:fea6:b916 prefixlen 64 scopeid 0x20
ether 06:f5:9f:a6:b9:16 txqueuelen 1000 (Ethernet)
RX packets 9587 bytes 1833640 (1.7 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 27678 bytes 4123030 (3.9 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 64 bytes 5920 (5.7 KiB)
TX packets 64 bytes 5920 (5.7 KiB)
tap_softether: flags=4163 mtu 1500
inet6 fe80::2ac:4fff:fee5:9bc8 prefixlen 64 scopeid 0x20
ether 00:ac:4f:e5:9b:c8 txqueuelen 1000 (Ethernet)
RX packets 1981 bytes 162880 (159.0 KiB)
TX packets 49 bytes 4038 (3.9 KiB)
iptables -L -n
Chain INPUT (policy DROP)
target prot opt source destination
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:53
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:67
DROP tcp -- 0.0.0.0/0 0.0.0.0/0 tcp flags:!0x17/0x02 state NEW
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:22
ACCEPT udp -- 10.8.0.0/24 0.0.0.0/0 udp dpt:53
ACCEPT icmp -- 10.8.0.0/24 0.0.0.0/0
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:500
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:4500
syn_flood tcp -- 0.0.0.0/0 0.0.0.0/0 tcp flags:0x17/0x02
Chain FORWARD (policy DROP)
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state NEW,RELATED,ESTABLISHED
ACCEPT all -- 10.8.0.0/24 10.8.0.0/24
Chain OUTPUT (policy DROP)
DROP icmp -- !127.39.95.47 !127.202.17.202 icmptype 3 code 3 connmark match ! 0x49ddb20f
DROP tcp -- !127.164.71.136 !127.179.167.180 tcp spts:61001:65535 flags:0x04/0x04 connmark match ! 0x3da56740
Chain syn_flood (1 references)
RETURN all -- 0.0.0.0/0 0.0.0.0/0 limit: avg 500/sec burst 2000
dnsmasq
interface=tap_softether
dhcp-range=tap_softether,10.8.0.2,10.8.0.200,12h
dhcp-option=tap_softether,3,10.8.0.1
server=8.8.8.8
Re: Not assigned ip address
Post by thisjun » Thu Sep 07, 2017 8:35 am
Is this information for the server or for the client?
Could you show the VPN server log?
