Setup Softether VPN with Server 2012 & Windows 10
harris008
Post by harris008 » Mon Aug 28, 2017 8:48 pm
Hi Support,
I would like to know if anyone has successfully configured Softether VPN on a Windows Server 2012 and managed to get a Windows 10 Pro workstation connected.
While connected one should be able to join the domain, and once restarted you should be able to map the network drives.
I have only managed to get Windows 7 and 8.1 working correctly.
There seems to be additional configuration required for Windows 10.
Any guidance would be appreciated.
Thank you
Mark.
Re: Setup Softether VPN with Server 2012 & Windows 10
Post by thisjun » Thu Sep 14, 2017 7:22 am
Did you use start-up connection?
