User authentication failed (code 9) after installing updates
BARRY
Post by BARRY » Mon Sep 11, 2017 12:39 am
I have a server setup on windows 2012 which authenticates against a radius server. it's been working great, until today. I installed windows updates. suddenly all authentication attempts return User authentication failed (code 9). It also appears that it's not even attempting authentication against the radius server. I say this because I should see the attempt on the radius server, but now nothing. A test to the radius server with a test app is good.
I also have verified I can ping the radius server from the soft ether server.
any ideas?
thank you
BARRY
Re: User authentication failed (code 9) after installing upd
Post by BARRY » Mon Sep 11, 2017 4:24 pm
bump
so much spam!
BARRY
Post by BARRY » Mon Sep 11, 2017 8:50 pm
if anyone ever sees this, the issue was on the radius server. for some reason it could not reach the vpn server. but it could reach the box with the test app
Re: User authentication failed (code 9) after installing updates
Post by thisjun » Tue Oct 17, 2017 4:25 am
Did you configure Radius auth on the VPN client?
