How to fix when google search is not working on your android device !
simmigravey
Post by simmigravey » Thu Feb 01, 2018 8:55 am
Google search is used for search anything on Google .It is commonly referred as web search engine.It handles more than 3 billion search each day.According to recent survey ,it has been become the most used search engine in the world.There are many language which are available on Google search.
When you use Google search on your android device then sometime it does not work in a proper way.Whenever you open any page then no page opens ,you need to fix this issue.we are describing some steps to resolve the issue if google search not working in android.You need to follow given below steps:
You need to go to the menu option then click on the settings option.
After that you will have to select manage application then search for All apps option.
Here you will have to scroll down to search anywhere.
Now you need to select clear data.
Now go to the application of Google and click on the Force stop.
Thereafter you need to return back to the home screen and restart your device.
You need to check Google search ,if it is working fine then it is ok.
Otherwise you need to open different browser ,here you need to check Google search.
Now Google search will work fine after using the above steps but still you are facing any issue then you need to use these below steps.It may work for you.
Initially , you need to check Internet connection
Go the settings of browser ,here you need to scroll down and select the search bar.
Here you need to choose Google as a default search engine.
You need to also choose default browser.
Now go to the on start up and select open the new page.
You need to go the history option of your browser and click on the clear browsing data.
After that you will have to close Your browser and again open it.
Now you will have to go to the Google website and search any thing which you want .
http://www.assistotalk.com/google-searc ... in-chrome/
osuji
Re: How to fix when google search is not working on your android device !
Post by osuji » Tue Feb 06, 2018 11:58 pm
Hi, i want to activate my plans this is osujianthony76@gmail.com
