connection to server failed
scialo
Post by scialo » Wed Feb 07, 2018 1:45 pm
i have installed vpn server on windows server 2008 r2 but when i try to connect it failed.
if open port it works!
help me?
scialo
Re: connection to server failed
Post by scialo » Fri Feb 09, 2018 9:51 am
is it possible my ISP block vpn connection?
scialo
Post by scialo » Thu Feb 15, 2018 11:26 am
help me?
Post by thisjun » Thu Mar 01, 2018 7:58 am
Does the VPN server work??? or not?
scialo
Post by scialo » Tue Mar 06, 2018 11:51 am
it works but when i trying to connect failed!
Post by thisjun » Wed Mar 14, 2018 7:08 am
Work but connect failed???
I can't understand it.
In what way do you use "work"?
scialo
Post by scialo » Tue Mar 20, 2018 10:40 am
i try connect on port 5555
softether installed on Windows Server 2008R2
fenice
Post by fenice » Tue Mar 20, 2018 10:46 am
Is that port open on the Windows firewall? Try a telnet to that port from another machine to check it.
Regards
Bill
scialo
Post by scialo » Tue Mar 20, 2018 11:28 am
if open port it works but don't want to resolve in this way.
fenice
Post by fenice » Tue Mar 20, 2018 11:47 am
If you're connecting to the VPN server from another machine then you have to open the firewall port otherwise you won't be able to connect, as you've already seen.
Regards
Bill
