SecureNat Virtual DHCP Question
zatco
Post by zatco » Thu Feb 08, 2018 9:27 pm
We currently use Softether with Virtual Nat and Secure Nat Virtual DHCP Server.
When trying to use the Mac address filter, the Virtual DHCP server creates virtual MAC addresses which makes it impossible to block connections based on MAC address.
If I was to disable the Virtual DHCP and an internal DHCP on the VPN VLAN to give out IP addresses, will this show to true MAC address of the Network adapter that is connecting via VPN?
Thanks
Re: SecureNat Virtual DHCP Question
Post by thisjun » Thu Mar 01, 2018 6:57 am
DHCP doesn't assign MAC address.
You can configure virtual NIC MAC address from property.
