How VPN Works in Mobile
Lindaawilsoon
Post by Lindaawilsoon » Tue Feb 20, 2018 7:37 am
Hi everyone,
I am new here and finding the best solution of my query that above mentioned in Title... i will be very thankful
How i installed VPN services in my android mobile and how it works
vlaryk
Re: How VPN Works in Mobile
Post by vlaryk » Wed Feb 21, 2018 9:52 am
How VPN works, you could / should read in Wikipedia.
You need not install it in your mobile, just configure and run
existing VPN client. L2TP/IPSec will do.
By the way, "mobile" is just about size, not operating system or model.
If you have Android 7 smartphone, it connects to SoftEther VPN server just fine.
Version 4 cannot connect. What is in the middle (5, 6), I don't know.
Windows Mobile also has VPN client.
Lindaawilsoon
Post by Lindaawilsoon » Fri Feb 23, 2018 5:34 am
> model.
> fine.
Mnay thanks vlaryk,
for delivering the easiest solution, actually i have Android 7 smartphone and its better to choose SoftEther VPN for my phone, let me look into from here
https://www.softether.org/5-download
vlaryk
Post by vlaryk » Fri Feb 23, 2018 9:16 am
I cannot understand at all, what exactly do you want .
So I can tell you only:
- you cannot set up SoftEther VPN server on your mobile
- you need not set up SoftEther VPN client on your mobile,
or any other client in order to use some existing SoftEther VPN server
- if you want to setup your own SoftEther VPN server,
and connect to it with your mobile, you can download
Linux or Windows server distribution, and install server
on Linux or Windows PC inside your home, work, or VDS/VPS network.
