VPN Client - Questions about auto-connect
skl
Post by skl » Sun Mar 11, 2018 2:19 am
Hello guys,
Two questions about auto-connect.
1. For roaming clients, is possible to auto-connect to VPN Server only when outside network?
Is there any solution for this case? When user is inside company network don't auto-connect to VPN and when outside the company network then auto-connect.
2. For global roaming users, is possible to configure a way to connect/choose to the nearest VPN server?
Re: VPN Client - Questions about auto-connect
Post by thisjun » Thu Mar 22, 2018 6:45 am
Would you make a script with vpncmd?
skl
Post by skl » Thu Mar 29, 2018 5:01 pm
Could you please give me an example using vpncmd ?
Post by thisjun » Wed Apr 18, 2018 7:00 am
What OS do you use?
gmj23
Post by gmj23 » Wed May 02, 2018 5:39 am
This is the same problem i am facing. We are using Windows clients and linux server. How can this be done?
Thanks.
gmj23
Post by gmj23 » Wed May 02, 2018 1:34 pm
shreerajneema, what does google duo have to do with this? Is there a way to make it control softether?
gmj23
Post by gmj23 » Thu May 03, 2018 4:45 pm
Anyone? Is there a solution to this? It puts a lot of unnecessary strain on the server.
Post by thisjun » Wed May 16, 2018 9:30 am
How can you determine that you are in the company's network?
