Proper SSL Configuration
gavstah
Contact:
Post by gavstah » Wed May 16, 2018 6:40 pm
Hi all,
Does anyone know of a how-to that explains the correct configuration of in-line SSL certificates in the OpenVPN client file? The documentation mentions that this is necessary, but it's a bit light on the actual details. I searched through the Softether manual as well, and no found no joy there.
Top Punkawallah
The VPN Company
http://goo.gl/iu6wG
Re: Proper SSL Configuration
Post by thisjun » Fri Jun 01, 2018 5:38 am
In-line SSL certificate is in .ovpn file that is generated by SoftEther VPN Server.
gavstah
Contact:
Post by gavstah » Sun Jun 03, 2018 3:36 pm
Hi Thisjun - thanks for your reply.
That's correct, but I was looking for actual step-by-step examples.
Top Punkawallah
The VPN Company
http://goo.gl/iu6wG
Post by thisjun » Thu Jun 14, 2018 8:34 am
The .ovpn file is generated automatically.
There isn't special configuration.
sammartin8935
Post by sammartin8935 » Thu Aug 30, 2018 10:39 am
This might help you with your concern:
https://docs.openvpn.net/configuration/installing-a-valid-ssl-web-certificate-in-access-server/
