connecting to LAN while on VPN?
xodc
Post by xodc » Sat Jul 07, 2018 11:03 pm
I have a Windows client connecting to a remote VPN hosted on AWS. The VPN uses SecureNAT and doesn't use local bridging.
From my client, when I connect to the VPN, I can no longer use some parts of my local network. For example, I can still type 192.168.0.101 to access another computer, but I can't access that computer by putting in its hostname.
What can I do to resolve this?
centeredki69
Re: connecting to LAN while on VPN?
Post by centeredki69 » Sun Jul 08, 2018 12:22 pm
Hello xodc,
On the client highlight the connection used to connect to the AWS VPN. Right click and choose "properties". Then choose " advanced settings" in the lower right. Then check the box also in the lower right ''No adjustment to routing tables"
See if that helps.
xodc
Post by xodc » Tue Jul 17, 2018 3:19 am
centeredki69 wrote:
> Hello xodc,
> See if that helps.
Thanks! That did seem to help for a while. But somehow, after a day it reverted back to not being able to access parts of the LAN. For example, here you can see how the IP address for a local NAS changes
[attachment=0]Screen Shot 2018-07-17 at 11.12.54 AM.png[/attachment][attachment=1]Screen Shot 2018-07-17 at 11.12.51 AM.png[/attachment]
Post by thisjun » Thu Aug 09, 2018 5:01 am
How did the client PC resolve the hostname on the local network?
I don't recommend to enable ''No adjustment to routing tables" option.
Usually, the VPN client keeps the route to the VPN server before the VPN connecting.
However, the option disables this behavior.
