Pre-Configured VPN Client Installer
ODITech
Post by ODITech » Tue Sep 25, 2018 1:16 pm
IS there any way to create a pre-configured VPN client installer package? What I would like to be able to do is have a link I can email to a user that they can click on to download and install the VPN client. When finished, they will be ready to connect. It will have all neccessary settings, client cert, etc. all set. It would save the hassle of having to talk to a remote user over the phone and try to walk them through the process of configuring the client on their end.
Thanks!
Re: Pre-Configured VPN Client Installer
Post by thisjun » Wed Oct 17, 2018 7:44 am
Please check "Easy Installer Creator" in Start menu.
ODITech
Post by ODITech » Wed Oct 17, 2018 5:54 pm
Great Thanks!! :)
cmd wh0ami
Post by cmd wh0ami » Wed Oct 17, 2018 7:17 pm
I'm guessing this only works to set up client on Windows?
Seems like every couple days I learn something new about SE even after using it for a couple years.
Post by thisjun » Thu Nov 01, 2018 6:52 am
Yes.
This tool creates an installer that installs virtual NIC automatically and connects VPN with a specified connection setting.
