cannot use ssh or rdp after connecting to vpn
yasharne
Post by yasharne » Fri Dec 07, 2018 8:10 pm
Hi
I have installed softether VPN server on a virtual machine running Ubuntu 16 and NATed a public IP to this VM. the problem is when I connect to the VPN server, I can ping other hosts with the same IP range but I cannot use ssh or RDP to connect to them, for ssh I get connection refused error. the only server machine which I can ssh to is the VPN server itself.
How can I fix this?
Re: cannot use ssh or rdp after connecting to vpn
Post by cedar » Mon Dec 10, 2018 9:53 am
It's a limitation of Linux.
https://www.softether.org/4-docs/1-manu ... r_Mac_OS_X
Please try add tap mode local bridge or attach to another eth interface to same segment.
