Is there an IRC channel?
feichtinger
Cli only
Post by feichtinger » Mon Mar 30, 2026 6:53 am
no pictures at all
no click, no double click
no explantion to set up without that
is there a possibility to download documents and manual?
Re: Cli only
Post by solo » Mon Mar 30, 2026 10:59 am
feichtinger
Re: Cli only
Post by feichtinger » Mon Mar 30, 2026 2:16 pm
perfectly welcome
extrordinally help
really thank you
that's just great
feichtinger
Re: Cli only
Post by feichtinger » Sun Apr 19, 2026 7:06 am
I tested chapter 6 quite a long time until I realized it's a
virtual machine. But it was a very good idea to make it
understandable completly.
Next I start from the very beginning to have a server one
time being interesting for others, there are very few clients
around here.
Re: Cli only
Post by solo » Sun Apr 19, 2026 8:38 am
You had asked about "servercontrol/statistic" elsewhere. Apart from GUI and CLI, it can be done also with JSON-RPC API https://github.com/SoftEtherVPN/SoftEth ... c-clients/
For example viewtopic.php?f=7&t=68181&p=98563#p98563
feichtinger
Surprise by a scriptkiddy
Post by feichtinger » Thu Apr 30, 2026 9:30 am
/f15539fc/c9a37686
/c834c44a/c9a37686
both very activ ad 755
load went up to 600
coming from a SoftEthethermember using *json.
I didn't inspect more.
Be carefull, some machines stop much earlier
Vale
feichtinger
nginx vpnbridge port80
Post by feichtinger » Thu May 14, 2026 12:11 pm
shouldn't for nginx port 443 be used when
vpnbridge occupies port 80 very fast at start?
feichtinger
Re: nginx vpnbridge port80
Post by feichtinger » Thu May 14, 2026 12:16 pm
ss -lntp grep -E '(:80¨\s|:80$)' showed the collision
feichtinger
xen - SoftEther
Post by feichtinger » Thu May 21, 2026 6:48 am
Why should anyone should want to have XEN when SoftEther works good?
Or the other way round: Whats the benefit when the own maschine works for anyone anywhere and isn't payed?
With xen it isn't my machine anylonger, just a funny virt part of what?
feichtinger
VPNCMD
Post by feichtinger » Fri May 22, 2026 11:45 am
Crahed dramatically
vpncmd does'nt let me write a password nor let me change anything nor let me stop anything.
(and killed permanently "systemctl restart gpm" and didn't let me use keyboard) from another
machine /bridge
softether -client
\server could be stopped and apt purge did the rest.
Then vpncmd could be started. Thanks CLI!
Restoring the rest by and by
Beware of the password!
feichtinger
Re: VPNCMD
Post by feichtinger » Fri May 22, 2026 12:39 pm
/usr/libexec/softether/vpnserver start
Answer
vpnserver start
-- Alert: SoftEther VPN Kernel --
Unable to create /run/softether/.VPN-FE9953974F. ???????????????
Why not: systemctl list-unit-files ????
Everything propper everything works fine?
Ahhh! Reinventing the wheel!
systemctl list-unit-files | grep softether* ???
feichtinger
Re: VPNCMD
Post by feichtinger » Sun May 24, 2026 9:32 am
crash repaired. everything fine
feichtinger
Debian stable CIi vpncmd 1
Post by feichtinger » Sun May 24, 2026 11:12 am
If connecting by server admin mode, please press Enter without inputting anything.
Specify Virtual Hub Name:
Error occurred. (Error code: 1)
Connection to the server failed. Check network connection and make sure that address and port number of destination server are correct.
Password:
Access has been denied. Possibly the password is incorrect, or perhaps you are connecting by an incorrect admin mode. You can try inputting the password again. To cancel, press Ctrl+D.
Password:
Who should own vpncmd? Where it should be linked to? should it be softlinked? to what should any program have access to?
Why isn't anything regulated via systemd? Who or what controlls?
Up to now after each use I have to reinstall Softeaterblock again, where are unixer, linuxer, what did they do?
feichtinger
Post by feichtinger » Sun May 24, 2026 11:46 am
anywhere and quite nice populated and not with gatemonks?
feichtinger
Re: Is there an IRC channel?
Post by feichtinger » Sun May 24, 2026 11:22 pm
vpncmd finally crashed
dpkg has to be repaired
systemd was reprairable
thanks for good and friendly help all the time
feichtinger is gone forever
