A new idea of virtual HUB cascade Gate
oscar
Post by oscar » Tue Sep 15, 2026 2:01 am
Just like https://www.vpngate.net does
https://www.softether.org/4-docs/1-manual/A/10.5
If you want to use a LAN segment as a group of VPN Gates [Virtual HUBs],you can publish your Virtual HUB info here -> http://www.packetix.net/en/ , also,please note that you can also publicly publish your hostname.vpnazure.net and just let the public internet use your hostname.vpnazure.net as a VPNGATE.
Also,if your own virtual HUB allows ALL Users on public internet to cascade into your virtual HUB,you can also run your own virtual HUB in such service all cascade GATE,this is purely archiveable via just by downloading https://www.softether-download.com/ja.aspx https://www.softether-download.com/en.aspx
Public internet users [Pro users] do not just simply use VPN Gate Client they can mix vpnserver vpnbridge vpnclient ALL-TOGETHER to build a VPN mixed environment they want,if the cascade feature can used as a VPN Gate public service,i personally think softether is the best place network engineers and geek tech savvy pro to have a party online.
