HOWTO use VPNGate and Android devices, no manual config.
First, download and install FEATVPN (FREE!):
Android 2.x/3.x Devices
http://www.featvpn.com/dl.php?id=1
Android 4.x Devices
http://www.featvpn.com/dl.php?id=2
This will install an OpenVPN client NO ROOT REQUIRED!
Once installed, you can setup tunnels, by simply downloading the the ovpn config files for the VPNGate node you wish to use.
Benefits:
Easy no hassle config
OpenVPN client - NO ROOT REQUIRED
Can use other OpenVPN VPN's
