I would like to build 2 server for anyone and I was build up server follow online guide, but I still can't see my server from globe site?
What wrong?? I using Windows Server 2008 R2 SP1.
Which port I need open?
Build up VPN Server
Re: Build up VPN Server
You installed SoftEther VPN Server and activated VPN Gate Function?
If so, wait for 10-15 mins and you will be able to find your server on the list.
If you cannot find your server on the list, please open the TCP ports on the TCP Listener List of VPN Server manually on your NAT/Firewall. VPN Gate Server automatically opens necessary TCP port on the UPnP-compatible router, however, non-UPnP routers must be configured to expose the TCP ports to the Internet.
1 server connect internet directly and another one is beside a router, I have tried to connect server via L2TP on my android mobile 4G network and no problem found, just not show on website only.
I can't see my server address online but have 3x user connected, is this normal?
