Anyone know what happen if I activate it in client? It only mention that activating it in Softether VPN Server will allows others to connect and use your IP.
Will it also happen with the client if I activate it? Or it will only serve as a list of VPN server that we can connect to?
Activating VPN Gate Server Relay in client?
iamsithlord
kh_tsang
Re: Activating VPN Gate Server Relay in client?
Yes as the information on vpngate.net. VpnGate function is only available on Windows version of Softether VPN Server and Softether VPN Client with the plugin
iamsithlord
So you mean vpn client with plugin will also act as VPN server? And my IP will be listed so ppl all over can use it?
