hi all
i installed vpn gate in one of my server
this server have 2 NIC
one for internet (Valid IP)
another one is connected to a MikroTik Router
and another one created by VPNGate
i wrote a masquerade for my LAN Users (LAN Range is 10.20.54.0/23) in mikrotik
but they dont have internet
what shall i do ? is there any suggestion to use vpn gate in my server and my users using this internet ?
Using VPN gate in my server
BoredAus
Re: Using VPN gate in my server
You need to describe your network setup better.
First, how are you connected to the internet? is the Mikrotik router acting as the gateway? or is your server hosting the internet connection to the internet and that Mikrotik just masquerades LAN clients?
Second, if your server is the gateway, are the LAN clients able to get internet access? i.e. did you bridge the two connections? This is without using VPN of any sort, just using your own connection.
