I need a dedicate OpenVPN server in UK.
Can someone help me?
thank you
best regards
Need a dedicate server in UK
Re: Need a dedicate server in UK
If you need a dedicated IP, you should purchase a VPS.
I already have it.
But some UK sites block the traffics from IPs of VPS/VPN and proxy. Thus I need an IP from a internet service provider.
Thank you
best regards
I already have it.
Thank you
best regards
Is it a UK IP? Some providers may use an ARIN IP in datacenter in other countries.
> countries.
It is a UK IP.. Confirmed by all site of geolocation.
> countries.
How about the WHOIS database? If it is also the UK, then your conclusion is correct.
I am using a Cloud VM in Japan. The geolocation of the IP is Japan(according to different IP geolocation sites) but it is an ARIN IP with the US as the registered as the address. Finally, I am treated as coming from the US on some websites and from Japan on some other sites.
Yes, it is a EDIS UK address.
Is this range of IP adddresses:
inetnum: 46.17.57.0 - 46.17.57.63
netname: EDIS-UK
descr: EDIS UK Services
country: GB
admin-c: GNOC
tech-c: GNOC
Thanks for the help
Best regards
netname: EDIS-UK
country: GB
admin-c: GNOC
tech-c: GNOC
Thanks for the help
Best regards
Then you will need to find your friends in the UK.
