Hi.
According to Softether VPN client, I am connected through an active VPN Gate Server (even the system tray icon blinks), however my IP remains the same. Tested through several VPN Gate servers, but to no avail.
Any suggestions?
TIA
gdotb
posted yesterday in the wrong forum apologies for the cross-posting
Connected but... not connected
Re: Connected but... not connected
Thanks, fenice.
I have also tried to uninstall and reinstall a freshly downloaded version (a couple of builds younger #lol, indeed), also to no avail.
I will not clutter the post with printscreens, unless someone requests, but everything looks as it should except ipconfig /all which shows the same IP address.
Best.
gdotb
Hi ALL.
Leeching back in the forum, I found a simple solution that actually worked...
Thanks, davidebeatrice
Best.
g.
Case closed #winkdavidebeatrici wrote: ↑Fri Nov 23, 2018 1:23 amPlease try to remove the virtual network adapter and create it again.
Best.
g.
You're welcome!
According to Softether VPN client, I am connected through an active VPN Gate Server (even the system tray icon blinks), however my IP remains the same. Tested through several VPN Gate servers, but to no avail.gdotb wrote: ↑Sat Jan 05, 2019 1:50 pmThanks, fenice.
Best.
gdotb
I have the same issue. Is there any other solution besides re-installing the VPN Network Adapter ?
