Connection Error: It was not possible to verify the identity of the server
zippedmails
Post by zippedmails » Tue Mar 10, 2020 8:18 pm
Hi all,
I am a newbie here, so please forgive me if I am raising an issue that may have been addressed before. But, I am posting after searching and failing to find any replies in the forum to the following problem:
I am trying to set up the VPN Gate on my Windows 10 device as per official instructions (https://www.vpngate.net/en/howto_l2tp.aspx#windows). However, each time I set up the vpn connection, I get the error: ["It was not possible to verify the identity of the server"], and the connection fails after trying to verify the user name and password (both inserted as "vpn"). So, what's causing this problem? Can someone show me the fix?
Thanks.
Nt_setvwy
Re: Connection Error: It was not possible to verify the identity of the server
Post by Nt_setvwy » Wed Mar 11, 2020 4:04 am
Try to specify the DNS server as the gateway device IP address, and DNS is also set in the operating system
zippedmails
Post by zippedmails » Wed Mar 11, 2020 8:12 am
Thanks for your reply buddy.
I have done that, but same result!!
Vue
Post by Vue » Fri Mar 13, 2020 9:11 am
Do all servers prompt this message?
