release vpn gate plugin separately
luweitest
Post by luweitest » Sat Apr 04, 2020 2:57 am
I downloaded SoftEther VPN client at another place. Now I download vpn gate zip file and find that the install file within are actually the same. If I rename the SoftEther VPN client install file "softether-vpnclient-v4.34-9744-beta-2020.03.20-windows-x86_x64-intel.exe" to "vpngate-client-v4.34-9744-beta-2020.03.20.exe", then it can install vpn gate files in the same directory normally. I suggest vpn gate files could be released separately, to be more flexible, and reduce the downloading size. I had hard times downloading such a big 60MB file through anti-GFW proxy.
